Thread: Can't clear cloudy water
    wrinkleigh is offline ** No working email address ** wrinkleigh 0
    Default Re: Can't clear cloudy water
    Sounds to me like you killed the algae because it all settled to the bottom, making your water clear. But when you turned on the pump, and circulated the water, it stirred it off the bottom, and made everything cloudy again.
    Only cure for this is to run the filter 24/7 until it filters all the dead algae out. It took mine about 3 days running 24/7.
    You can floc, and shock and clarify all day long -- but filtering and time is what you need.
    Warwick, R.I., U.S.A..
    Keep the filter running until it's clear. I have been running 4 days now on a 12,000 AG and I'm almost there.
    If you are holding your proper cl level based on your cya through the day, and your CC is 0 then you should be done with the shock phase but you do need to get rid of the dead algae, that's the cloud you are seeing.
    IF I may add to the mantra here: BBBP; Bleach, Baking Soda, Borax, and Patience.
    As Ben says: POP; Pool Owner Patience.
    Follow EXACTLY what you are told to do in this forum and you will succeed, these folks really know their stuff!
    Wayne
    Although I don't have a valving system on my filter, I found that some valves can recirculate the water without filtering. Make sure you're filtering.
  1. Water is cloudy. Want to clear up before closing
    By Jacob99 in forum Dealing with Algae & Slime
    Last Post: 09-29-2012, 07:38 PM
  2. Clear up cloudy water
    By bross1990 in forum Dealing with Algae & Slime
    Last Post: 07-26-2012, 02:59 PM
  3. Cloudy water won't clear up
    By Batman77 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-25-2011, 08:21 AM
  4. Crystal clear water but turns cloudy once swimmers get in
    By joelq in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-15-2007, 04:30 PM
  5. Cloudy water on Clear Comfort
    By densar24 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-22-2006, 11:39 AM
