Thread: New Liner installed, chem #s
    May 2012
    Kentucky
    Question New Liner installed, chem #s
    Hi all, I had a new liner installed a week or so ago. I could use some advice on getting the chemistry right.
    2 days of testing after installer initially treated water, here are my numbers.
    FC 9.0
    CC 0
    PH <7.0
    TA 70
    CYA 60
    How much Borax should I add to raise Ph or should I just wait a while? How do the other numbers look? I know FC is high for now, what Level should I maintain? I should say that it probably be 4 to 6 weeks before pool is warm enough to swim around my area. It's good to be about to start another season. Hope everyone had a great winter!!!
    Thanks!
    17k gal 16' x 32' IG concrete bottom FG sides 1985 , Hayward Pro S244T sand filter , Hayward Super pump 1 HP 12 - 24 hrs , using 8.25% bleach, K-2006C kit. PF=7
    Default Re: New Liner installed, chem #s
    FC's not too high for a CYA of 60. Check out the "Best Guess" table. There's no answer to how much Borax to add. Try a quarter box at a time, and check pH after an hour or two after each add.
  1. Chem log, to see....
    By Charlie_R in forum Pool Chemistry for Intex-type Pools
    Last Post: 09-05-2012, 09:16 PM
  2. Calling All Chem Geeks (incl. THE Chem Geek) re: storing pool chems
    By elsie in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-10-2011, 10:20 PM
  3. Wrinkles in newly installed pool liner
    By heatherwpg in forum In-Ground Pool Construction and Repair
    Last Post: 06-10-2011, 12:31 PM
  4. Will Polaris 380 Cause Excessive wear to Liner Installed on Rough PoolKrete Bottom?
    By webfeet in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-05-2006, 10:08 PM
  5. new liner being installed..filling with well water
    By tazt60968 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-12-2006, 12:15 AM
