Results 11 to 15 of 15
Thread: If this was your fill water, what would you do?
    BigDave's Avatar
    Default Re: If this was your fill water, what would you do?
    Nice recordkeeping! What kind of chlorine are you adding? How did you add the CYA?
    Bosch232 is offline Registered+ Thread Analyst Bosch232 0
    Aug 2012
    Nebraska
    Chlorine and CYA are just HTH from Wal Mart. Granular versions of both.
    I'm a bit uncertain about the CYA, because I added 2 lbs and the test still says ZERO.
    So I'm not quite sure I've got that dialed in.
    16x32 Oval AG vinyl pool; Media Master sand filter; 1.5 hp 1 speed pump; 10 hrs; Rural utility water; Taylor K-2006
    Aug 2012
    Nebraska
    I didn't exactly answer your question.. I've added both to the skimmer, slowly pouring it in.
    BigDave's Avatar
    CYA can take a long time to dissolve - don't bother testing for 4-5 days after adding granular CYA.
    There are a couple types of powder chlorine - most likely Dichlor or Cal-hypo. Dichlor adds CYA, Cal-hypo doesn't. Either is OK right now as you need CYA but it's good to know what to expect. Which do you have?
    Aug 2012
    Nebraska
    Thanks for the heads-up about CYA - I would have probably added more too soon if you hadn't told me that.
    I put in 47% cal-hypo. This: http://www.walmart.com/ip/HTH-Chlori...nules/17043619
    So far, the water is sparkling clear.
    Thank you for your help in my start up.
    It's only 45 deg here, what crap...
  1. Testing fill water
    By Budlight592 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-10-2012, 06:55 PM
  2. Fill with only 1 foot of water and don't fill for 24-48 hours?
    By Jacob99 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-26-2012, 07:00 PM
  3. Ok to fill pool using well water?
    By DanNH in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-20-2011, 12:45 AM
  4. High TA in fill water
    By AndyJ in forum Dealing with Alkalinity and Calcium
    Last Post: 06-10-2010, 11:01 PM
  5. City or well for fill water
    By StevenW in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-22-2006, 09:29 PM
