I've decided, finally, going into my 11th season with my FantaSea pool, to get into the wonderful world of SWCGs!
I still cannot justify the cost vs regular maintenance and adding LC or bleach, but I'm going to be away several times during the summer and I'm always a little nervous relying on someone else to add LC on schedule. I've always said if you're going to be away a lot that SWCGs are the way to go.
So I've ordered a PoolPilot and matching cell and manifold.
Meantime, I have installed an outdoor 220v outlet that piggy-backs on the pump's outlet. Since the pump outlet is already on a GFI breaker and a timer, it's just a matter of wiring a cable to the PoolPilot and plugging it in and the timer will control both.
If I find I have the "rising pH syndrome" I can add a 5 gallon acid pump to the system to compensate.
So...at least I have the wiring part done. I will have to re-plumb my return manifold using PVC instead of TigerFlex, at least for part of it to support the cell manifold.
Measure-Cut-Glue, Measure-Cut-Glue, repeat as necessary!
BTW, thanks to PoolSean for his great guidance!
