Results 1 to 10 of 16
Thread: switching to saltwater
    Virginia
    Default Re: switching to saltwater
    If you do go for an Intex SWCG, be aware that it may include a copper ionizer feature. This feature puts copper ions in the pool water - something that's not very popular around here.
    Copper can stain the pool, fingernails, and light colored hair (lightened and colored as well) green. It also has the somewhat dubious effect of supressing algae without killing bacteria. In other words, the copper can help a pool look clean while allowing bacteria to pass between swimmers (or from below the waist of a swimmer to above the neck - yuck!). Perhaps there's a way to defeat this feature.
    That's good to know that Intex may include that "feature". In my early days of pool ownership when I depended on the pool store to tell me what to do (long before discovering this great forum!) I used a copper based algaecide. After discovering it was the cause of staining everything (it was a pain and expensive to get rid of!) I would never use anything copper based again! I've since learned here that my algae problem could have been solved by just maintaining appropriate chlorine levels in relation to my stabilizer level.
    Jul 2012
    Mexico, Missouri
    I have read elsewhere that there is a way to disconnect the copper ion section, but may not have to do that. Amazon still sells the older units without this "feature", so might pull the trigger on one when end of season sales go into effect.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
  1. Switching from Ionization need Help
    By wil804 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-09-2012, 09:14 AM
  2. Considering switching to salt generator
    By Coolair in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-26-2011, 12:07 AM
  3. Switching Pool to SWG
    By jl1965 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-12-2008, 09:51 PM
  4. Switching to Bleach?
    By JimSentry in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-13-2006, 10:57 PM
  5. Switching to BBB. What do I do with these numbers?
    By thewayne in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2006, 08:24 AM
