Results 1 to 10 of 16
Thread: switching to saltwater
    Default Re: switching to saltwater
    I'm in the process of switching to SWCG as well. I have the plumbing done. I just now need to hook up the electrical and mount the panel...and add salt to my pool. I have a Taylor test kit and it reads 600ppm. So I've got 400# of salt in my truck to add.
    It's not a cost savings. The salt cost alone is about a season's worth of chlorine. It's the convenience because I cannot test the water everyday.
    May 2010
    Congrats Carl, I hope you enjoy the SWCG. How's it going so far? I agree completely, it is a bit of a money pit to be honest, but I wouldn't trade it for any other method. Once you get through the learning curve, it is simply wonderful.
    Virginia
    I agree all things considered (cost of unit, cells, etc) it's not likely you would save much, if any, over more traditional methods. However, cost of salt isn't a big deal. While you may have to add several hundred pounds initially, after that its just a matter of maintaining the level. And as mentioned, salt is only lost when you lose water due to splash out, back washing to waste, lowering the water level due to excessive rain, etc.
    No way the math works out to save me money versus daily checking and using LC. The initial cost of the SWCG would buy me 10 years of chlorine--15 if I had had someone else install it. Plus a new cell every 5 years costs about the same as 5 years of LC, so it's NOT a cost savings in any way, shape or form.
    But, I'm going to be away for a couple of weeks at a time this summer and I won't always have someone to add half a gallon of LC every two days, so this gives me a MUCH easier to maintain pool when I cannot give it daily attention.
    While my water is great (FC: 12.5, pH: 7.3, T/A:70, CH: 150, CYA: 70) I still have to work out the optimal settings..otherwise it's going great!
    Virginia
    Agreed. . I was mearly pointing out that the cost of salt, over time, isn't a big factor. As you said, the biggies are the cost of the system and the cells.
    The pool stores like to say you will save money, but as you pointed out its not true. For me, having a SWCG is about convenience (I like the way the salt water feels as well, but I guess you could do the same with a traditionally chlorinated pool).
    The math flat-out doesn't add up--not even close. It's the convenience factor that does it. I've said for years now I couldn't justify the cost, because I had no need for the added convenience. Now I do. So far, so good, too.
    Virginia
    Which CL generator did you go with?
    An Autopilot digital, upgradeable to run an acid pump and control the two speed pump.
  1. Switching from Ionization need Help
    By wil804 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-09-2012, 10:14 AM
  2. Considering switching to salt generator
    By Coolair in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-26-2011, 01:07 AM
  3. Switching Pool to SWG
    By jl1965 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-12-2008, 10:51 PM
  4. Switching to Bleach?
    By JimSentry in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-13-2006, 11:57 PM
  5. Switching to BBB. What do I do with these numbers?
    By thewayne in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2006, 09:24 AM
