Results 1 to 10 of 50
Thread: My Green Pool Saga - Help!
    Pamsel is offline Registered+ Thread Analyst Pamsel 0
    Central Illinois
    Default Re: My Green Pool Saga - Help!
    Thank you Janet. I have learned more here in two days than I've learned the past 4 years from pool "experts". I have a new container of both the pucks and the oxidizer. I'll be happy to return them and recover some of my money. Many thanks again.
    HELP again!!
    I tested the water first thing this morning. My chlorine level is high now - 10ppm, showing almost brownish-yellow and I smell chlorine when I walk up to the pool. I will maintain this level now until the algae is killed? So far, the water has not changed appearance at all. Also, my PH has not come down at all and my TA has gone from 310 to 380. I've put in 48ozs of muriatic acid in four doses so far, but am getting no results. Could someone please tell me if perhaps I read the PH Calcs chart wrong? I put in 14,500 gal for pool size and click calculate. The muriatic acid line reads 11.6, which I took to mean I should put in 11.6 ozs.
    I've been putting in 12 ozs at a time. Am I doing something wrong?
    I discovered that I have a container of PH Reducer (Sodium Bisulfate) in the garage, left from the previous owners. This means it is 5 years old. Would it do any good to use that, since the muratic acid doesn't seem to be doing the trick? Or would that be going in reverse?
    Thanks again!
    Pam, Illinois
    "17'x33' oval 14.5K gal IG vinyl pool; liquid chlorine; Hayward Pro Series, M-S-244T sand filter; A.O. Smith Centurian, Switchless, 1.40 HP pump; Right now 24/7hrs; Pool Solutions PS234
    Serial #6511, Drops / Powder; Community well; summer: none; winter: mesh; ; PF:8.3"
    HI PAMSEL!
    mbar (Marie) PM'd me and asked me to look at this thread. Perhaps I can explain a few things.
    First, your high pH.....
    Your ALK is very high, this is what is making it so difficult to change your pH. Total Alklinity is just a name for the buffer system in the water that keeps the pH from bouncing up and down. If it is too high then the pH doesn't want to move and it can take a LOT of acid and airating to get it in line...Once it is you won't have the problem with pH control. You can use up the dry acid (sodium bisulfate) but it is not as effective as muriatic acid. Once it is gone it is more economical to stick to muriatic acid. High pH also makes your chlorine less effective. I am going to spare you all the chemistry but that is another reason to get your ALK and pH in range. Your chlorine will work better.
    With very high ALK you will be putting in acid and nothing seems to happen. just put more in later in the day and test your pH again... You are going to find a point when the pH starts to come down...you have finally overcome the buffer in the water. At this point your pH will come down as you add acid. Calculators and dosage charts really work best when your parameters are within normal ranges. When something is as out of whack as your ALK readings they are not going to really give you correct dosage info.
    ONE IMPORTANT THING. If your chlorine levels are high it will interfere with the pH test. Once again I will spare you the chemistry but you will test at 8.2 even though the pH is much lower than that!. I would not test pH right after adding chlorine or any time you have much over 10 ppm chlorine in the water! Ditto for trying to lower the ALK. Deal with one thing at a time until you get everything in line.
    As far as the huge chlorine demand that your pool was showing and the algae problem, That is a bit complicated but I will try and explain it. You have been using trichlor pucks which put stabilizer in the water then you closed your pool and when you opened you had no stabilizer. Where did the stabilizer go? Bacteria ate it while the pool was closed and excreted ammonia and urea compounds. These will eat up chlorine fast until they are finally 'burned off'. It can take a LOT of chlorine to do this as you have seen.
    You said that you are finally holding chlorine and can smell it. If you can smell it you need more! The smell is combined chlorine (CC)....this means that the chorine is staring to burn off the ammonia compounds in your water. Keep hitting the pool with chlorine, BRUSH, BRUSH, BRUSH, and vacumn as much out of the pool that you can. Keep cleaning your filter....As you kill the algae and get the stuff out of the water you will find your chlorine levels are holding and the strong smell goes away. Once the pool is clear let the chlorine levels drop to normal ranges and start working on your ALK and pH.
    You have gotten very good advice so far from the other posters, and as you can see, it is starting to work. You have also gotten some very bad advice from the pool stores.
    ONE red flag when up when you said '3 month algacide' What brand? All the ones I have seen are copper based and copper can make the water green ( but not cloudy), especially if you are shocking the pool a lot. The good news is the same sequstering agent that will help you get rid of the iron will also do the same for the copper. If you know your fill water is yellow with iron then you must keep a sequestering agent in your pool all the time. Follow the directions on the bottle to a letter for the initial treatment and for maintenance. Be sure to add a bit evey time you add new fill water also.
    One last thing, to extend the range of your chlorine test you can dilute the pool water with distilled water, mix them, and then test (a shot glass makes a good measure). Here's how:
    1 part pool water, 1 part distilled water, multiply the reading by 2....you can now read up to 10 ppm Total Chlorine.
    1 part pool water, 2 parts distilled water, multiply the reading by 3....you can now read up to 15 ppm Total Chlorine.
    1 part pool water, 3 parts distilled water, multiply the reading by 4....you can now read up to 20 ppm Total Chlorine.
    1 part pool water, 4 parts distilled water, multiply the reading by 5....you can now read up to 25 ppm Total Chlorine.
    The test kit you have will not read FC accurately, As soon as you can try to find a kit that uses FAS-DPD to test for FC and CC. Most of us on the forum use the kit that Ben sells on the sister website www.poolsolutions.com
    There are also good kits from Taylor Technologies and LaMotte that use this test for FC and CC but Ben's kit is definitely the best 'bang for your buck'. The kit you have right now is fine to get you started but if you really want to take control of your pool and save some money invest in a good kit. You have already found that the pool stores near you just use strips. Strips are fine for a quick check just to make sure everything is within range but are usless for adjusting anything. For example, how can you ajust your pH when you only know it is somewhere betwwen 7.2 and 7.8, which is the scale on most of the test strips I have seen!
    From what I saw in your last few posts you are making real progress. Just keep at it and you WILL be swimming soon!
    Hope this has been helpful and didn't confuse you!
    Smile Re: My Green Pool Saga - Help!
    Greetings all, and welcome to the forum Pamsel, sorry I've missed out on all the fun so far, Marie pm'd me (& Evan) to take a gander at this thread. Let me take a whack at helping this 'Pamsel in distress'
    The info you've received thus far is good, I see a couple things that haven't been adressed. :
    You did the partial drain and refill, which water source did you use for the refill? Your TA increased, instead of going down, I suspect you used the community water and that it is high in TA (& possibly iron) have you used the same source to 'top off' the pool for the past 5 years? I don't want to give you more work, but I do want to help you, please have the community water and the pond water tested for the usual perameters and metals and let us know the results. (I'm thinking that the pond water will test better than the community water, and will be your prefered (though not optimal) method of filling the pool, a little pond scum can be dealt with by a bottle of bleach, high alk and metal tap water will require more costly chems and more time to correct)
    I can't remember if anyone told you about the problem of cya being algae food over the winter, Ben has a riff on it somewhere (could one of you computer literate folks please link it up - who knows what would be the result if I tried) and he says it can take a ton of bleach to get the problem taken care of.
    One last thing, I'm hearing thunder and don't want to fry my pc, when using the sequestering agent, place a chlorinating tab in the skimmer, you need the cya anyway, it'll help the metal come out of solution in the filter where it belongs. As for adding granular cya (stabiliser) put it in an old kneehigh or pair of pantyhose and just drop the packet in the skimmer.
    Thanks for the compliment Marie in asking for my input! I hope this adds a little to the thread and lets Pamsel get swimming soon!!
    Quote Originally Posted by waste
    Don't do this if you have a cartridge filter. The low pH from the trichlor could cause damage to the cartridge. If you have a sand or DE filter it can help the metals precipitate out on the sand or the DE but run the pump continuously while you do this.
    Central Illinois
    Thank you Waterbear and Waste . . . very helpful posts! I have been trying to correct PH, TA and CL at the same time. I guess I'll concentrate on one thing at a time. At 8:30 pm I tested (2 hrs. after my last 24 oz dose of acid) and my PH has finally come down - 7.5 now (but I'm wondering now if the reading is accurate since my chlorine is high). My TA is still at 330 and CL reading above the kit range - orange in color. I will do the dilution method in the morning when I test and am going to get Ben's kit so I can do this right. Even though the numbers are starting to improve, the appearance of the water is not yet. I have been brushing, but have not vacuumed to waste since I started this process yesterday, since I can't see the bottom, but I will vacuum anyway. Problem with that is, then I have to add more water again. . .
    Waterbear, the 3-mo algicide is Pool Pride brand, and I just looked at my invoice and it is listed as Copper Algicide. I guess that answers that question.
    Waste, I did use the community well water to refill and yes, I have used it to top off for the last 5 years. I will have my husband see about getting the water tested and see which source is best.
    My heartfelt thanks to each of you for caring and helping! It is greatly appreciated. I will keep you posted.
    "Pamsel the Damsel" (in distress)
    Pam, Illinois
    Check your pH once the chlorine level is below about 10 or 15 ppm. It should be in the ballpark if you have a decent test kit. the 'cheapo' ones are usually worse about the interferance but the better kits by Taylor, LaMotte, and the kit sold on the poolsolutions website work pretty well up to about 15 ppm chlorine. Even the cheap walmart 6 way kit works at chlorine levels up to a bit over 10 ppm but if your chlorine is really high even these kits will show a PH of 8.2 or close to it when the pH is actually lower.
    Central Illinois
    I have the Wal-Mart kit. It was the only place within 30 miles that had anything that tests for CYA. I plan to concentrate on the CL level now, brush and vacuum and stop with the acid until the water clears up. I am continuing to aerate. If this is not the right plan, someone please correct me.
    Pam, Illinois
  1. The saga of cracked pool.
    By Amir in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2007, 06:42 PM
  2. Dolphin climbing saga....
    By scott747 in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-25-2007, 10:42 AM
  3. My suction side leak Saga
    By lmnharris in forum Pool Equipment & Operations
    Last Post: 08-24-2006, 05:57 PM
  4. New Pool start-up saga...
    By Maxout in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2006, 02:08 PM
  5. Ben's Test Kit saga
    By Bleach=Chlorine? in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-05-2006, 03:08 PM
