Thread: Baquacil
    Southeast Missouri
    Default Re: Baquacil
    I have a 32,000 gallon pool and ran Baquacil for 3 years. The last year I ran it cost me over $1,200 and never seen the bottom. I stopped counting after that...didn't want to know how much it was costing me. I had never owned a pool before and the pool store convinced me that the Baquacil was the best way to go, won't fade your liner, burn your eyes, etc. I trusted them but now I know why they wanted me to use it....it put alot of money in their pockets!!!
    I was nervous about converting because I didn't know how to run a chlorine pool and the pool store told me all the horrors of having a chlorine pool and Baquacil was much easier to maintain.
    I found this site four years ago and converted as stated here. I now spend less than 6 dollars a week most of the time....it would be less if I strictly use bleach but I am gone a lot so I use pucks some of the time. My water is as clear as it can be, doesn't smell, no eye's burning, etc. I get comments all the time on how clear my pool stays. I don't freak out everytime it storms thinking about how much its going to cost me to clear the pool up again. I was actually thinking about filling my pool in and now I love my pool again.
    I would strongly recommend you to switch over and you won't believe how easy it is to take care of your pool by using the Bleach, Borax, Baking Soda method. I also strongly recommend you to buy the test kit offered on this site so you never have to depend on a pool store to know what you need to add to your water to keep it in perfect shape. It saved me the cost of the kit the first month.
    There are plenty of people here to help you if you run into a problem so just ask.
    Take care and good luck.
    Folks, thanks for all the help...Sorry that I posted on different sites initially as I was learning how to navigate the forum...Given that I live in NJ,I have a limited pool span and want to maximize as much of time as possible...Rtaher not have to waste potentially 2 weeks of short season if possible..Anyway, Pool has finally cleared for now and I will most definitely be doing the BBB switch by next season...
    Good luck with it .
  1. Success with Baquacil so far
    By ccr-n-ia in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-30-2007, 11:22 PM
  2. Baquacil Help
    By Ac44cw in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-31-2006, 03:17 PM
  3. To Baquacil or not to Baquacil...that is the question.
    By radialaced in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-07-2006, 10:03 PM
  4. Baquacil in a hot tub
    By sock monkey in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-02-2006, 12:50 PM
  5. Baquacil Conversion Done, Now what
    By bcpoolowner in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-22-2006, 12:13 AM
