Thread: Waterco CC100 ideal pressure
    pfgroth Guest
    Default Waterco CC100 ideal pressure
    Hi, I have a Waterco CC100 filter.
    The sticker on the outside of the filter says pressure should not exceed 350 kPa.
    My pressure reading is quite low, around 20 kPa.
    Is my pressure too low? What is the ideal value?
    thanks,
    Peter
    mas985's Avatar
    Pleasanton, CA
    Default Re: Waterco CC100 ideal pressure
    There is no such thing as an ideal pressure. There are too many variables. But generally, lower pressure is better because it can mean that there is low return head loss. But it can also mean that there is high suction head loss. It all depends on the rest of your equipment.
    Mark
  1. Ph is ideal, alkalinity is a little high
    By Mftek1 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-15-2013, 04:54 PM
  2. Waterco F600 top mount multiport valve sand filter - removing the valve
    By wojie24 in forum Pool Equipment & Operations
    Last Post: 10-29-2011, 10:41 PM
  3. Ideal Levels
    By iwannapool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-06-2007, 09:23 AM
  4. Hayward versus Waterco?
    By kaydee in forum Pool Equipment & Operations
    Last Post: 04-20-2006, 02:06 PM
