Thread: Does air temperature affect pH? How about water temperature?
    Default Re: Does air temperature affect pH? How about water temperature?
    I don't think that air temps directly affect pH, but they do affect how fast chlorine is used up--and high chlorine levels will give falsely high pH readings. Have you shocked the pool lately, and maybe the chlorine levels haven't come down yet?
    As water temperature drops, the pH rises if all else were equal. This due to the temperature dependence of the various pH equilibrium reactions. This natural effect tends to keep the saturation index from changing as much when the temperature changes.
    However, at cooler water temps, the rate of carbon dioxide outgassing should be slowing down so I would have expected the pH to become more stable. So I don't understand why you are using so much more acid; the pH tending to rise more is a mystery.
    Dec 2012
    Colorado
    " . . . the pH tending to rise more is a mystery. "
    As of 12/14 - it's still whacked (sigh).
  1. Water Temperature for Pool Closing
    By Pamlicoknk in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-05-2011, 06:43 PM
  2. Water temperature and pool opening
    By framcus in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2007, 09:16 PM
  3. Water temperature and Algea
    By Guido in forum Dealing with Algae & Slime
    Last Post: 07-18-2006, 11:07 AM
  4. Water temperature for swimming
    By GreenLight in forum Pool Equipment & Operations
    Last Post: 06-02-2006, 11:08 PM
  5. Algae/Water Temperature
    By kjsmom in forum Dealing with Algae & Slime
    Last Post: 04-25-2006, 07:41 PM
