Closed Thread
Thread: Anyone Ever Used a "Leak Sealer" ?
    Default Anyone Ever Used a "Leak Sealer" ?
    I'm just about certain I have a leak in my pipes between my skimmer and the pump, underground. Has anyone ever used a Leak Sealer.
    Something like this?
    What causes these products to supposedly work?
    http://www.lo-chlor.com/pool_chemicals/leak_sealer.php
    Morris, IL
    Default Re: Anyone Ever Used a "Leak Sealer" ?
    Well, I was a plumber for ten years and I would seriously doubt it. Can you see the leak? If so, then replumb it, if not, then hook air to it and air test it, with an air compressor you should be able to hear the water and air hissing out of the leak.
Closed Thread
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  2. How to check for DE filter "leak"?
    By jkmhb in forum Pool Equipment & Operations
    Last Post: 06-24-2011, 07:56 PM
  3. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  4. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
