Thread: Aqua Rite motherboard replacement wiring
    Default Aqua Rite motherboard replacement wiring
    OK, so my motherboard was fried (2 very black spots burned thru). It is an old system, and the motherboard changed in 10/04 I think. The fuse is different now. So I pull the orange and yellow wires and put in the new fuse. Thing is, I accidentally also pull the orange and yellow wires off the regulators. Unfortunately, there are 2 open connectors on each regulator--- one is unused. And I do not remember which one it was.
    Can someone tell me where the other end of the yellow and orange wires connect (upper right corner, or....etc)?
    Thanks,
    Noel
    Default Re: Aqua Rite motherboard replacement wiring
    Anyone?
    Anybody willing to just pull the 2 screws that hold the faceplate and take at look for me?
    mas985's Avatar
    Pleasanton, CA
    It should be one of the these pictures, no?
    https://www.google.com/search?num=50...M4K1iwLq5IGYCQ
    Mark
    Virginia
    Sorry for the late reply. Don't know if you found your answer yet (did you try calling the manufacturer?), but if not, I'd be happy to take a peek at my Aqua Rite and let you know what I see.
  1. Aqua Rite Question
    By wataka88 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-15-2011, 03:33 PM
  2. Aqua Rite cell is bad
    By moreyes in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-15-2010, 06:30 PM
  3. Aqua RiteŽ Jr. ?
    By BND in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-05-2007, 07:53 PM
  4. New Aqua Rite
    By Simmons99 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-06-2006, 04:01 PM
  5. Aqua-rite Swg
    By DONNIE in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-31-2006, 09:01 PM
