Generally it is not worth the effort. Each 90 is worth only a few feet of pipe and a small amount of pressure loss. Plus if you go with swept 90s they only reduce the head loss by about 50% of only those fittings and make plumbing a nightmare on the pad. Check this one out:
BTW, you will get most bang from your buck by up sizing the pipe so you are much better off going with 2.5" pipe and keeping conventional fittings rather than just changing the 90s.
