Thread: Older pool with tight 90 deg bends
    Nov 2012
    Minnesota
    Default Older pool with tight 90 deg bends
    I'm looking into is articles on pressure loss and I'm wondering if it's worth the trouble to replace the many tight 90 deg elbows in the system with wider ones. I have over ten of them and I want to move the pump and filter away from the pool as they were installed too close in my opinion and them I could enclose them to reduce operating noise and get them out of the sun.
    Has anyone replaced theirs and noticed a difference? Or at least felt it was worth the time and effort?
    mas985's Avatar
    Pleasanton, CA
    Default Re: Older pool with tight 90 deg bends
    Generally it is not worth the effort. Each 90 is worth only a few feet of pipe and a small amount of pressure loss. Plus if you go with swept 90s they only reduce the head loss by about 50% of only those fittings and make plumbing a nightmare on the pad. Check this one out:
    BTW, you will get most bang from your buck by up sizing the pipe so you are much better off going with 2.5" pipe and keeping conventional fittings rather than just changing the 90s.
    Mark
  1. New owner of older in ground pool
    By chkirla in forum --cleanup--
    Last Post: 11-08-2012, 03:58 AM
  2. Our new AGP installed in a tight space with pics
    By geohec in forum Above-Ground Pool Construction & Repair
    Last Post: 09-17-2012, 02:23 AM
  3. recovering fiberglas coping around older inground pool
    By moneypit48 in forum In-Ground Pool Construction and Repair
    Last Post: 07-14-2012, 12:14 AM
  4. need help with older pool
    By Matt1006 in forum In-Ground Pool Construction and Repair
    Last Post: 08-02-2011, 03:35 PM
  5. How tight to make pump lid?
    By GWNorth in forum Pool Equipment & Operations
    Last Post: 05-02-2009, 07:39 PM
