Thread: Closing Pool :(
    Jul 2012
    Cincinnati, OH
    Default Closing Pool :(
    Closing The pool for the winter...way to late(cinci OH here). Had a the best year ever thanks to your help. I just wanted to post my final readings to see if anyone had any advice:
    FC-8 CC-0 PH-7.5 TA-8 CYA-62,,,,,,Water is clear New liner this year
    Thanks again
    18x40 Lazy L 30K gal IG Vinyl pool; tri-clor feeder; Hayward #250 sand sand filter; Hayward super-1-1/2 HP pump; ; Taylor 2006c; utility water- PF:4
    Default Re: Closing Pool :(
    Your numbers look ok but if it were my pool, I'd take the chlorine up a little higher to around 15ish and I'd also bump the pH up to around 7.8 or so. I'm in WV and rainfall drops my pH. That gives me some "wiggle" room if the pH falls any. (I'm pretty sure your TA of 8 is a typo.....)
    You are welcome. Glad you have had a good swim season!
    Jul 2012
    Cincinnati, OH
    Thanks mom rain does the same in cincy.....TA was 80
    Quote Originally Posted by 392papa View Post
    That is what I thought on both accounts.
    You're welcome, by the way!
  1. Closing a.g. Pool
    By willis1 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-15-2012, 11:23 PM
  2. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  3. Closing Pool the BBB way
    By DavidP77 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-21-2007, 10:26 PM
  4. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 10:50 PM
  5. Closing pool
    By bryjen in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-19-2006, 10:24 AM
