I lubed the gasket and the problem seems to be no better. When the pool shuts off all the water immediately dumps from the system. There is a constantly soggy area where the lines go underground. I had thought it was being caused by some leaks at the pump and Polaris but I fixed those leaks and the ground is still very wet. Do I need to do some digging or is this a bigger job that will require bids? Thanks.
? Thanks.
