Thread: Excessive air in system
    Jul 2006
    Default Excessive air in system
    My pool is continuously belching air into the pool through the jets. I recently changed the pump but I can find no leaks. Bleeding the air out the top of the filter helps but does not solve the problem. Thanks for any input!
    22,000 gal in ground
    sand filter
    Houston
    mas985's Avatar
    Pleasanton, CA
    Default Re: Excessive air in system
    You have an air leak on the suction side of the pump. Since you recently changed the pump, it is likely to be the pump basket lid or the couplings if the pump has those. Use some pool lube on both and see if that helps.
    Mark
    Jul 2006
    I lubed the gasket and the problem seems to be no better. When the pool shuts off all the water immediately dumps from the system. There is a constantly soggy area where the lines go underground. I had thought it was being caused by some leaks at the pump and Polaris but I fixed those leaks and the ground is still very wet. Do I need to do some digging or is this a bigger job that will require bids ? Thanks.
    sand filter
    Houston
    mas985's Avatar
    Pleasanton, CA
    Sounds like a pretty bad leak. The pipes are usually 2'-3' below ground so it does require a lot of digging although the soil is nice wet so it shouldn't be too hard. But you really need to decide for yourself if you are up to the task of both finding and repairing the leak.
    Mark
  1. Seems excessive
    By mfwade in forum General Interest
    Last Post: 06-27-2012, 10:44 AM
  2. Will Polaris 380 Cause Excessive wear to Liner Installed on Rough PoolKrete Bottom?
    By webfeet in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-05-2006, 11:08 PM
  3. DE Filter, excessive bumping
    By aimee3 in forum Pool Equipment & Operations
    Last Post: 08-14-2006, 01:08 AM
  4. Update on excessive bleach consumption
    By VOLDADDY in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-18-2006, 06:37 PM
  5. Excessive bleach consumption
    Last Post: 06-11-2006, 10:27 PM
