Thread: Swimspa conversion
    Default Re: Swimspa conversion
    Do you keep it covered or is it exposed to sunlight? If the first a modified BBB called the dichlor/bleach method will work. This modification is documented on PoolSpaForum.com in the hot tub water chemistry section of the forum. If your swim spa is uncovered and exposed to sunlight then you would want to use straignt BBB as documented here. If it is undcovered (and unheated) in summer and covered and heated in winter then treat it as a BBB pool in the summer and a dichlor/bleach in winter but be aware of a few things :
    ozone can increase chlorine demand (the amount of chlorine needed to maintain a certain FC level) because the two destroy each other.
    The CYA levels required for summer and winter could be quite different so you might have to do a partial drain and refill to switch to dichlor/bleach. With a 4000 gal swim spa this might not be trivial. In a best case you can get by with no higher than 40 ppm CYA in the summer and can drop it back to 30 ppm CYA in winter so this might not be a problem at all or yo might find that you can manage on the same CYA level in both summer and winter. Your main problem will be pH control because of the increased aeration in a swim spa (like in a spa). This is easily dealt with by lowering the TA to about 50-70 ppm and adding 50 ppm borate if needed. Is your swim spa vinyl or fiberglass (the usual materials)?
    Oct 2012
    Toronto
    We have a fiberglass swimspa. I really appreciate your guidance.
  1. 1 year after conversion
    By jeffmull in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 09-03-2012, 08:28 PM
  2. Hydropool SwimSpa 19'
    By bluehole in forum In-Ground Pool Construction and Repair
    Last Post: 01-06-2012, 01:42 PM
  3. jandy conversion to PDA
    By Abish in forum Pool Equipment & Operations
    Last Post: 01-07-2007, 09:33 AM
  4. conversion
    By chalk2024 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-20-2006, 10:47 PM
  5. conversion
    By bwalsh1 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-27-2006, 01:33 PM
