It doesn't leak, I pressure tested it. And it's plumbed separate. All other return lines go through one pipe, into the ground, and split in a manifold somewhere underground. This one return has it's own pipe. Is there any reason you'd want one return to bypass the automatic chlorine feeder? I have a T just before the feeder which is capped off as well and looks like it might line up with this capped pipe.
