Thread: Plugged Return Line Newbie
    Oct 2012
    Michigan
    Default Re: Plugged Return Line Newbie
    Update, I had a capped pipe near my filter so I had a hunch and drilled a hole in it. Sure enough it goes to that jet. Why would there be a jet that's piped separate from the rest of the system, and then why would it be capped? I blew it out and capped it again this time on both ends to keep it winterized. Any insight?
    I have no idea--I just wanted to pop in and let you know that forum traffic slows way down this time of year, so you will probably get responses, but it may take awhile to get them. Don't give up!
    BigDave's Avatar
    Maybe it leaks and the previous owner just retired it in place?
    Oct 2012
    Michigan
    It doesn't leak, I pressure tested it. And it's plumbed separate. All other return lines go through one pipe, into the ground, and split in a manifold somewhere underground. This one return has it's own pipe. Is there any reason you'd want one return to bypass the automatic chlorine feeder? I have a T just before the feeder which is capped off as well and looks like it might line up with this capped pipe.
    It's a mystery. The line is good, just capped?
  1. Possible Return Line Leak
    By wddupree in forum --cleanup--
    Last Post: 01-06-2013, 10:43 PM
  2. Is one return line enough?
    By McDug in forum In-Ground Pool Construction and Repair
    Last Post: 06-19-2012, 11:45 PM
  3. all 4 pool return ports are plugged
    By craig in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2011, 02:06 PM
  4. Air in filter/return line
    By scsteven in forum Above-Ground Pool Construction & Repair
    Last Post: 07-08-2006, 08:48 PM
  5. Return line
    By crosso in forum In-Ground Pool Construction and Repair
    Last Post: 05-08-2006, 09:24 AM
