Hi, and welcome to the forum!
In order to fight a bad case of mustard algae, you're going to need to be able to test your water yourself instead of relying on the pool store for testing. We highly recommend the K-2006 test kit in the link in my sig (you will have to log out to the main forum page and then the testkit link will be in the sig of any post made by me, Watermom, or Pooldoc). We need a set of test results taken with a drop-based kit, as well as a list of what chems you've put into the pool so far ingredient names, not product names like "algaecide".). We also need to know your primary source of chlorination, and the size/type of your pump and filter setup.
If you can supply us with that info, we'll be glad to help! BTW, while you're logged out and following links from our sigs, click the google search link and search for mustard algae--it should return a wealth of other threads from the forum and archives for you to read so you'll have an idea what you're up against.
