Thread: Closing....when to add algaecide?
    Virginia
    Default Closing....when to add algaecide?
    I read not to add algaecide right after shocking because the chlorine would break down the algaecide. The article said to shock a couple days before adding the winter algaecide.
    A "couple days before" seems pretty vague given it doesn't state a shock level. So my question is, how low should I let the chlorine drop before adding the winter algaecide?
    My CYA level is about 80, so my shock level would be about 21 if I understand correctly. Chlorine demand is pretty low right now with the colder water temps so it would probably take more than a couple days for the chlorine to return to "normal" levels (about 5ppm).
    My other levels are:
    pH - 7.5
    borates - 60
    TA - 90
    CC - 0
    Thanks.
    Default Re: Closing....when to add algaecide?
    What I do is bring my FC up to shock level, then I put in a quart of 60% Polyquat algaecide. I wait 48 hours for the FC to drop, then test the water, and add chlorine to bring it back up to shock level. Then I close. This generally keeps me from having a problem in the spring, if I open early enough.
    Virginia
    Thanks for sharing your experience.
    Supposedly, according to what I read, high chlorine levels break down the algaecide, hence my question. I guess what I'll do is shock then wait until chlorine drops back down to a "normal" level (about 5ppm in my case with CYA at about 80) before adding the winter algaecide.
  1. Use of algaecide
    By onemsmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2013, 05:33 PM
  2. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  3. Is any Algaecide better than nothing?
    By NullQwerty in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-16-2006, 09:17 PM
  4. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 10:50 PM
  5. Algaecide
    By MartyW in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-20-2006, 11:41 PM
