Results 1 to 10 of 11
Thread: to add de or not to add de
    Default Re: to add de or not to add de
    I just converted from the EC65 to the S244T also. You mentioned 250 lbs. of sand - shouldn't you have 300 lbs. in your filter? That's what I put in mine.
    mikemedic is offline ** No working email address ** Thread Analyst mikemedic 0
    West Virginia
    yes your a correct
    I did put 6 /50 lb. bags in
    Sorry total of 300 lbs of sand
    Mike
    gregugadawg Guest
    why did you guys go from a d.e. filter to a sand filter
    Quote Originally Posted by gregugadawg
    For me, it was because of ease of maintenance. With the old DE filter, I had no way to backwash. It was old and leaky. I was a nightmare to open with its 15 bolts holding the top on. I could go on, but I will just stop here...
    gregugadawg Guest
    ahh old school, the new d.e. filters do have backwash valves on them now so the only extra maintenance is reapplying the d.e. but that is neither here nor there. You could add some d.e. to coat the sand bed, typically you would add enough to see a 1psi increase in pressure. Just be sure to monitor your filter pressure regularly as the pressure will go up much faster than with the sand filter.
    duraleigh Guest
    Good morning, guys,
    I am a BIG sand filter advocate. Anecdotally, I have twice filled my pool with murky pond water. My sand filter and plenty of Clorox (NOTHING more) has cleaned my pool water to an absolutely pristine condition.
    Mike, post up some numbers and test your Cl level frequently. I am not kidding, 95% of the water clarity problems on this forum can be solved with adequate amounts of chlorine. Most people simply don't realize how quickly it is consumed by organics and/or the Sun without adequate CYA.
    Mike, the DE will be washed out as soon as you backwash, (which should be often in this clearing process) so I don't see it offering much benefit. I truly believe your issue is chlorine but without test results, you and I are both just guessing.
    Greenlight and Mike both, there are thousands and thousands of crystal clear pools out there that only use sand. It is a proven medium that, plain and simply, works. Additionally, you will find it the most trouble-free filter you can operate.
    West Virginia
    Ok here are my numbers
    PH-7.8
    Free CL- 20
    CYA is now down to 90..Yaay! was 150
    CC-1
    Alk- 110
    Free Cl went down to 8 after draining half the water then filling last night
    Dumped bleach to raise the Free CL to 20
    Tested this am.
    WIll test again tonight
    Pool still green
    I't got me frustrated, it's going to be 90 degrees in West Virginia today
    Happy Memorial day everyone
    Any suggestions would be appreciated
    Mike
