Thread: Spa with Clear Choice wants better sanitation
    Sep 2012
    Phoenix
    Default Spa with Clear Choice wants better sanitation
    I have an acrylic spa (Lucite with Microban), with a warranty predicated on using Clear Choice system. I'm interested in learning about options or additional ways to sanitize our spa. Thanks.
    Default Re: Spa with Clear Choice wants better sanitation
    Hi, and welcome to the forum!
    This forum is mainly geared toward water chemistry relating to swimming pools, and doesn't really address spas, since they are a completely different animal. You are welcome to log out and use the google search feature in my sig to search around the forum for info, but you might do better to try poolspaforum DOT com, where they deal mainly with spas. At least one of our regular contributors is a moderator over there, so if you see info that you're not sure of, it would be fine to come back here and double check that info with him. Otherwise, I'm afraid you might not get much in the way of suggestions, especially now since most folks are closing down their pools for the winter and forum traffic has fallen off.
  1. Best Method for Pool and Spa Sanitation for Chlorine Allergy
    By LarryFlorida in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-19-2013, 03:25 PM
  2. Defending EcoSmarte and sanitation via copper ionization
    By ernie1959 in forum The China Shop
    Last Post: 05-09-2012, 07:53 PM
  3. Intex's mongrel SWCG + Copper sanitation unit
    By PoolDoc in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-10-2011, 12:54 PM
  4. pool tile choice
    By poolfor3kids in forum Pool Equipment & Operations
    Last Post: 09-14-2006, 02:26 PM
  5. Vinyl Pool Construction Choice Of Walls
    By StuartHB in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2006, 09:32 PM
