Thread: Above ground Pump...In Ground Pump????
    Default Re: Above ground Pump...In Ground Pump????
    To add to Mark's points. As a rough rule-of-thumb, IG pumps are usually rated in "full-rated" HP, but AG pumps are usually rated in "Up-rated" HP. I crudely figure an up-rated 1hp pump has, at most 2/3 the power and flow of a 1hp full-rated pump. That's really, really crude. From a pumping POV, 8k isn't a big pool. I run a 20K pool with a 1hp 2speed IG (full-rated) pump and pretty much run all the time at low speed--at most 1/3 HP, probably less, including my solar panels.
    Aug 2012
    Manteca, CA
    Thanks to all for the info, most helpful!!
    11x32 rectangle 8K* gal IG concrete pool; Bleach; American Products DE filter; 1 speed pump; 12 -16 hrs; solar heat; HTH 6 Way test kit ( from Walmart); utility water; summer: none; winter: none; Wireless network & a laptop; PF:15
  1. Pump Replacement Recommendation (In-Ground)
    By Tooner in forum Pool Equipment & Operations
    Last Post: 06-28-2012, 02:04 AM
  2. Looking for reliable above ground pool pump
    By JKainer in forum Pool Equipment & Operations
    Last Post: 05-05-2012, 06:09 PM
  3. Above ground pool pump questions
    By khager in forum Pool Equipment & Operations
    Last Post: 03-30-2009, 08:54 PM
  4. In ground pool hot tub drains when pump is on????
    By mjlepak in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2008, 10:01 AM
  5. Above Ground Two Speed Pump
    By DavidP77 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-22-2007, 11:54 AM
