Thread: Pool lighting problem - they're all out
    Default Pool lighting problem - they're all out
    I have a 30k gallon inground pool with 2 lights, then an attached spa with 1 light. Everything was working fine a week ago, now NONE of the lights are working. It seems like a weird coincidence that all three bulbs would go at the same time. Can I tell by looking at the bulb if it needs replacement? They are Jandy Jazz lights, connected to an Aqualink controller. If I turn the lights on, I can hear the controller click on, and the controller thinks they are on.
    Any suggestions?
    Fred
    May 2010
    Default Re: Pool lighting problem - they're all out
    Those lights should be wired to a GFI breaker that has probably tripped. Check the breakers that you may have in the Jandy box. GFI breaker for the lights is sometimes a outlet GFI on the right side of the Jandy box (out side of it).
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
  1. Pool Lighting Trips GFI
    By jfitch in forum In-Ground Pool Construction and Repair
    Last Post: 07-30-2012, 11:22 AM
  2. lighting around pool/yard
    By SS1304 in forum Pool Equipment & Operations
    Last Post: 05-17-2011, 08:06 PM
  3. Pool/ Spa Lighting
    By divnkd101 in forum Pool Equipment & Operations
    Last Post: 10-20-2006, 12:05 AM
  4. pool lighting/electrical question
    By ryanm in forum Pool Equipment & Operations
    Last Post: 07-04-2006, 07:04 PM
  5. Low voltage lighting safe around inground pool?
    By joelq in forum Pool Equipment & Operations
    Last Post: 06-08-2006, 01:51 PM
