Results 1 to 8 of 8
Thread: Horsepower Ratings vs. Actual Consumption
    Sep 2012
    Montreal, Canada
    Default Re: Horsepower Ratings vs. Actual Consumption
    Thanks for the information and the california energy comission link. It was very interesting.
    I had the Hayward Super Pumps in 1hp, 1.5hp, and 2.0hp, as well as the hayward Tristar 1hp tested for flow vs. Amp draw.
    The 1.0 hp Super pump was drawing 1600 watts at about 50ft of Head flow rate, the 1.5hp -2040 watts at 50ft of head, and the 2.0 hp 2400 watts at 50ft. The 1.0hp Tristar was Drawing around 1750w. THis was all on the same setup and using a valve and flow meter to vary restriction in the piping.
    The 1.0hp tristar flowed more than the 2.0hp Super Pump for much less energy, but all of the pumps, regardless of the Hayward HP ratings consumed a lot more wattage than their nameplates.
    mas985's Avatar
    Pleasanton, CA
    Who did you have test the pumps because those numbers do not look correct?
    Mark
    Sep 2012
    Montreal, Canada
    Tested them in the lab at one of my clients. They make heat pumps, so the equipment is quite precise. The wattages above are rough averages of what we datalogged. We reduced flow to several GPM increments and kept datalogs of the amperage draws for each of the pumps.
    mas985's Avatar
    Pleasanton, CA
    The CEC measurements for the Superpump are well below what you measured so something is wrong. Are you sure the pumps weren't Super IIs instead of the Superpump? There is a big difference between the two.
    The full rate 1 HP Tristar is within operating limits so that one I believe.
    Mark
  1. Salt Level not showing actual values
    By bpark in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-14-2012, 12:09 PM
  2. Pump motor horsepower?
    By aylad in forum Pool Equipment & Operations
    Last Post: 03-30-2012, 02:05 PM
  3. New user looking for above ground pool reviews, ratings n user pics of pools
    By Piggiesinlove in forum In-Ground Pool Construction and Repair
    Last Post: 07-19-2011, 06:08 PM
  4. Is my FC consumption reasonable?
    By Water_man in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-03-2008, 03:39 PM
  5. Chlorine Consumption Rate
    By chemicalbalance in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2007, 12:27 PM
