Thread: Chemicals necessary for closing my pool
    Headed West Guest
    Default Chemicals necessary for closing my pool
    One of the beneficial things i have learned from pool Forum this year is a more judicious use of pool chemicals. I have a 30K gal pool and will shut it down this weekend. What PF members or pooldoc recommend to keep the pool more or less in goid shape over a northern VA winter?
    Default Re: Chemicals necessary for closing my pool
    I just use chlorine and Polyquat and I'm in NJ. But I lived in NoVA for 10 years and while the winters are a little milder than they are here, they aren't much milder.
    If you haven't already done so, read the closing 'stickies' at the top of the pool startup and shutdown section of the forum.
    Welcome to the Pool Forum by the way!
  1. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 03:36 PM
  2. Help w Chemicals for Above Ground Pool Closing
    By vlapinta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-21-2009, 04:36 PM
  3. What chemicals are needed for closing?
    By DanS in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-28-2008, 08:40 PM
  4. Can someone take my hand after the chemicals and pool is clean on closing
    By traceyb in forum Above-Ground Pool Construction & Repair
    Last Post: 10-11-2006, 07:24 AM
  5. Plan on closing today, but read about polyquat dosage prior to closing...
    By The Raddish in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-06-2006, 09:50 PM
