Thread: Advice needed for mostly unmanaged pool
    Default Re: Advice needed for mostly unmanaged pool
    Is there no one that can stop by once a week or so to dump A dose of liquid chlorine? If so you could raise the CYA to 150 or so and just run a high CYA/ hgh chlorine pool. Besides that, or maybe a SWCG, I don't know what to suggest. You just can't properly care for a pool without physically being there.
    San Antonio, TX
    Hi Janet,
    Thanks for the suggestions. I had not thought about going the high CYA route, but it does make sense. There is usually someone there every week or every other week during the swimming season, so if I can come up with some simple instructions (such as add 1 bottle of bleach) I might be able to make it work. I'll have to store the bleach in a different location from the rest of my chemicals, otherwise people would be tempted to "self medicate" the pool, which was another problem I had to address.
    The SWG is also a great idea -- perhaps the better one. I know I really like the one I have for my home pool, and the idea of having the campground pool regularly chlorinated when it is unattended seems to be a better solution than to have a high dose on a sporadic basis. It would also cut out problems with coordinating the maintenance of the pool among several people. I only have experience with IG SWGs -- I assume it would be the same for the AG? As I mentioned earlier, I replaced the original pump/filter with a standard (Hayward) sand filter and pump, so I would think that adding the smallest in-line SWG on the return would probably work. Am I overlooking anything? Thanks again for your help!
    Lou
    I don't know anything about the sizing of SWCGs, but you might want to look through this thread to see if this helps any...
    http://www.poolforum.com/pf2/showthr...sizing-of-unit
    Also, I don't know about about possible corrosion issues on the AG pool--I know that adding SWCG to most AG pools will void the warranty, but I don't know if this is an issue for you or not. Just something to think about.
  1. NEW! (AG pool & to forums) some advice needed
    By Timmy425Oldstyle in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-31-2012, 12:11 PM
  2. Advice on repairing pool needed..!
    By payperview in forum Above-Ground Pool Construction & Repair
    Last Post: 06-28-2011, 07:57 PM
  3. Check_In and Advice Needed
    By Orkalovesfood in forum DPD-FAS based testing
    Last Post: 06-08-2007, 11:22 AM
  4. Major problems, advice needed...
    By Strawfoot in forum In-Ground Pool Construction and Repair
    Last Post: 12-14-2006, 02:22 PM
  5. Decking Advice Needed
    By Bearbacker in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2006, 04:25 PM
