Thread: Is stabilizer needed late in the year for shutdown?
    Ontario.
    Default Re: Is stabilizer needed late in the year for shutdown?
    waterbear, in Nova Scotia Pibster is likely winterizing and closing the pool within the next month. The cost of stabilizer may be greater than the chlorine to get to shut down. Though there could be benefit in helping to retain the chlorine level after closed, and until the water starts to freeze up.
    Would this change the stabilizer recommendation for this circumstance?
    I would really want to see the test resutls first. Even for a month it might be a good idea. It might be worthwhile to chlorinate with dichlor instead of bleach since it will add 9 ppm CYA for every 10 ppm chlorine added BUT without knowing the current stabilizer level and the daily FC loss and if there is any CC it really is impossible to say. There could also be something esle going on such as a nascent algae bloom and that would not be good right before closing.
    Finally:
    Quote Originally Posted by Pibster View Post
    PH and alkalinity are fine
    are not test results that give us any useful info.
  1. First year pool high stabilizer and algae
    By ksherman in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-14-2013, 08:35 PM
  2. Replies: 3
    Last Post: 05-21-2013, 03:16 PM
  3. Emergency Shutdown
    By bobcat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-16-2011, 10:17 PM
  4. Normal for DE to be in pump strainer after shutdown?
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-12-2007, 12:18 AM
