Thread: Planning a pool in Dallas. Planning questions.
    Sep 2012
    Frisco, Texas
    Default Planning a pool in Dallas. Planning questions.
    Hi,
    I am currently planning a pool in north Dallas and I am trying to decide on a way to clean the water. So far I am leaning towards a SWCG system. I was looking into Ozone and UV but decided against those. I guess some of my questions would be are there any materials for the coping around the pool to consider since I am going salt? Any to stay away from? I guess the only chlorine, besides the salt generator, I need to worry about would be for shocking, which I would go liquid.
    Filter is going to be cartridge, pump will be variable speed. Interior will be pebble. I am also going to add a slide, aerators, raised spa and the deck will be exposed aggregate to match what we already have and to keep the cost down.
    Any input for the planning stage will be appreciated.
    Mike
    Default Re: Planning a pool in Dallas. Planning questions.
    Remember: A slide and aerator will cause....aeration ( ), which, in turn continually raises pH, so be prepared for that. Also, many SWCG systems seem to raise pH as well (not sure why--our resident chemists can explain it better). So you will constantly be compensating for one or both. That's ok, but expect it, and expect to add acid all the time.
    SWCG is, of course, a chlorine system so other forms of chlorine work with it. I would suggest strongly that when the pool is new you use floaters full of tri-chlor tabs to both raise your stabilizer level to the SWCG manufacturer's suggested level (usually 60-80ppm) and, because tri-chlor is very acidic, to help keep the pH under control, especially when the walls of the pool are curing.
    Be sure to buy a Taylor K-2006 or K-2006C test kit before you fill the pool. From Day 1 it will be your BFF for maintaining your pool.
    Sep 2012
    Frisco, Texas
    Thanks for the information. I guess I will look for a pool company that supports my wish of a SWCG. If they don't I will move on.
    Quote Originally Posted by mmcaleer View Post
    Hi,
    Just to clarify ...... SWCGs don't clean water.
  1. Pool Planning
    By Rock_Crusher in forum In-Ground Pool Construction and Repair
    Last Post: 09-10-2012, 10:46 PM
  2. Planning a pool
    By LeavinlvSchwarjw in forum In-Ground Pool Construction and Repair
    Last Post: 07-09-2012, 12:09 PM
  3. Planning an AG pool
    By BethyM in forum Above-Ground Pool Construction & Repair
    Last Post: 06-26-2012, 12:14 AM
  4. Planning to GC own pool
    By cdocon in forum In-Ground Pool Construction and Repair
    Last Post: 03-06-2012, 04:51 PM
  5. Planning, designing new pool.
    By Jeffski in forum In-Ground Pool Construction and Repair
    Last Post: 06-14-2006, 07:48 PM
