Results 1 to 10 of 16
Thread: New Member: Pool Filter: Sand vs DE
    Sep 2012
    South Texas
    Default Re: New Member: Pool Filter: Sand vs DE
    When I was asking the installer about the sand filter he indicated that the sand filter has to be back washed at least once per week where a DE is only backwashed once per month. I guess that would depend on how dirty your pool was but that would make a difference in the amount of water & chemicals thrown away. Any experience one way or the other. Number of times you backwash and with what type of filter?
    You use less water with DE.
    But, DE filters have to be manually opened and cleaned at least 1x per season. If you go with DE, make sure you get a filter you can manage. It takes 8 hands to re-assemble some models .
    Virginia
    Quote Originally Posted by pooldoc View Post
    ..... It takes 8 hands to re-assemble some models .
    lol
    I had to laugh because I have a DE filter (Hayward Pro Grid 6020) and it does take a little practice taking it apart for cleaning and reassembling (I do this at the end of every season and have gotten pretty good at it ).
    That said, I like my DE filter. Keep in mind though this is the only filter I've used. It was installed in 2004 when we had the pool installed; our first and only pool, btw. So I really can't say if I would still like it better than a sand filter.
    It does a great job keeping the pool clean. Once spring clean up is done I usually only have to backwash/recharge with DE once during the season (early May to early Oct here). This season after spring clean up I haven't had to backwash at all.
    Some don't like to handle DE powder. I don't mind so much; I just make sure I'm not inhaling it when recharging the filter.
    In terms of expense to maintain, I would think sand would be cheapest, followed by DE, then cartridges being the most expensive.
    It's probably more important that filter/pump be sized correctly than whether you choose sand or DE.
    Quote Originally Posted by mnittler View Post
    You do NOT have to backwash a sand filter once a week. You only need to backwash when the filter pressure rises 8-10psi over clean filter pressure. I only backwash a handful of times the entire summer.
    I only back wash when my pressure rises noticeably.
    Virginia
    I guess I should have specified this in my post, but I also backwash when pressure rises 8-10psi over clean pressure. I guess this has been an "extra clean" year as I haven't had to backwash all season.
  1. New Member/Hose from Pump to filter
    By jrg1372 in forum Above-Ground Pool Construction & Repair
    Last Post: 09-03-2012, 03:56 AM
  2. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
