Is My Filter (Hayward DE) not working?
I have hayward DE 6000 filter and have an inground pool cleaning system (polaris caretaker 99 pop-up system).
We have few palm trees around the pool and they have these seeds coming down all the time.
I have two skimmer openings. I assume the water which comes through the first skimmer, goes to the second one and gets sucked in by the pump? The first one has a basket with wide spacing net, and the second one has finer one. Or probably they are both connected directly to the pool and not one after the other? I can see flow in both of them.
My problem is that these palm seeds gets through these skimmers and even comes out of the filter and gets clogged in the cone strainer right at the pop-up systems valve dome. I have to take apart the dome valve every hour or so and clean it out or else the pop-up system does not get the water and funtion. Does it mean that the filter grids are broken? or have holes in them? Is there any other possible way those seeds can end up at the pop-up system strainer (I think its placed after the filter)? Thanks!
18x32 kidney 15K gal IG Gunite pool; skimmer tabs; Hayward DE6000 DE filter; Hayward/AO Smith Superflow 1 speed pump; 12 hrs; heat pump, fountain or waterfall; Taylor K2006C ; utility water; summer: none; winter: none; android tablet; PF:8
