Thread: Black dots on bottom area of linner
    Aug 2010
    North of Waco, Texas
    Exclamation Black dots on bottom area of linner
    I have black dots appearing only on the bottom of the linner on my above ground pool. I first noticed 3 or 4 of these last year. I was very late removing my cover this year, about July 15th due to install problems with plumbing on a SWCG.
    Now there are a couple dozen from 1/16" to 5/16" in size. They look like they could have been made with a sharpe or magic marker. I went into the pool with a fine nylon scouring pad and using my foot I tried to scrub away a couple with no luck. The spots did not appear to get any lighter or deminish in size or depth of color from the scrubbing.
    Any thoughts ???
    16X32 vinyl AG Doughboy 12,600 gal w/ deck down one side. 19" Doughboy filter, 1.5 hp Hayward pump, CircuPool RJ20 SWCG, 440 pounds salt, maintaining 30 ppm borates; CYA 60ppm.
    Default Re: Black dots on bottom area of linner
    Do the spots feel slimy? Can you scrape any of it up under a fingernail and smear it on a piece of white paper?
    Aug 2010
    There is no difference to the fell of the spots or the normal liner. They wont wipe, scrap or in any way be diminished by scraping with a finger nail, or a rubbing with a fine nylon scouring pad. They look like a sharpie has been used to make them! At a few of the spots it looks like it my be degrading the integrity of the liner under the spot.
  1. Black Spots on bottom of pool
    By PoolNewbies in forum Dealing with Algae & Slime
    Last Post: 06-25-2013, 09:27 AM
  2. Black spots on bottom of pool??
    By cbaird in forum Dealing with Algae & Slime
    Last Post: 06-02-2013, 01:20 PM
  3. Solar cover and black-bottom IG pool
    By dafletcha in forum Pool Equipment & Operations
    Last Post: 09-10-2006, 10:12 PM
