Thread: Questions for heater repairman...
    Jul 2012
    Mexico, Missouri
    Default Re: Questions for heater repairman...
    Thanks for the update.
    Yes, reading instructions is something that many of us "forget" to do, and we usually end up wiping egg from our faces....
    It's great that you got everything sorted though, so go out and enjoy your pool!
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Ontario.
    What kind of heater do you have, and what is the fuel. eg. Natural gas, propane, electric.
    I have had a natural gas heater for years, and it is only about a foot from the house, and it never affected the siding. Gas regulations required it to be a minimum distance from all windows. That could be a regulation in your area, or for you fuel type. I would inquire on exactly what the reg is and read if for yourself. If you are out of reg. or code, you should move it to ensure your insurance coverage is not affected.
    My first heat was a Jandy with a wind stack for venting, and the stack come from the middle of the heater, so it was a couple of feet from the siding. The siding got more heat from the sun than the heater. My new heater is a Hayward lo-nox and it doesn't require a wind stack. No heat problems there.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
  1. Questions about a new propane heater.
    By smacd in forum Pool Equipment & Operations
    Last Post: 05-27-2011, 03:04 PM
  2. new heater questions
    By vinouspleasure in forum Pool Equipment & Operations
    Last Post: 06-19-2010, 01:57 PM
  3. New Pool Owner Questions - 8 questions!! :)
    By kmmlangston in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2010, 05:33 PM
  4. Solar Panel Heater Questions
    By NullQwerty in forum Pool Equipment & Operations
    Last Post: 05-27-2007, 10:35 PM
  5. Can't run heater below 40f???
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-17-2006, 03:51 PM
