Thread: Leaky Return
    Jul 2012
    Ontario, Canada
    Default Leaky Return
    Hey -
    Just finished my AGP install, finally
    It's pretty good, except I've got a leak on my return:
    It's only a drop or two every few seconds, so nothing major. I can't notice anything causing the leak, and I've tightend the return nut.
    The block of wood is there to support the salt cell, as it seems to be putting stress because it's not supported.
    The only thing I can think, is I think I forgot to put that white tape around the big grey nut. Could that be it? If it is, do I have to drain my pool to the return to take it off and re-tape?
    Any ideas how to figure this out/fix it?
    Thanks,
    Brad
    Jul 2012
    Mexico, Missouri
    Default Re: Leaky Return
    Try tightening the nut one flat. If that doesn't work, you can try this:
    If the water isn't too cold, try having someone in the pool, holding a large bowl over the return, while you work on it from the outside.
    If it turns out that you don't have the rubber sealing washer on the inside of the pool, you can still use the bowl routine, but you will lose a little water while you quickly move the bowl long enough to slip the washer into place.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Jul 2012
    Ontario, Canada
    THanks Charlie -...I've tightened that return quite a bit, and there is a rubber seal around it.
    Never thought of the bowl idea...so I will do that and put some teflon tape around the nut...
  1. Leaky filter
    By hsides in forum Pool Equipment & Operations
    Last Post: 07-21-2012, 12:48 PM
  2. Help with a leaky light...
    By mariner09 in forum Pool Equipment & Operations
    Last Post: 05-02-2008, 09:33 PM
  3. Quick fix for leaky return line
    By kissinger99 in forum In-Ground Pool Construction and Repair
    Last Post: 08-23-2006, 04:48 PM
  4. leaky nuts.....
    By amyinraleigh in forum Above-Ground Pool Construction & Repair
    Last Post: 07-17-2006, 01:54 PM
  5. Leaky connections -- what to use?
    By Mom2Czars in forum Above-Ground Pool Construction & Repair
    Last Post: 07-14-2006, 12:40 PM
