Results 11 to 11 of 11
Thread: Cloudy Green Pool - Vacuum and Brush?
    Brooklyn, NY
    Default Re: Cloudy Green Pool
    Yeah I definately know I need a better tester and have been searching for a good one at QUITE a few stores. They all seem to have strips here in Brooklyn, NY. I also looked to order Bens but the Order page only lists Pre ordering the ps234 with a 2 - 4 week delivery time.
    As far as the PH and CYA - I was under the impression (and PLEASE correct me if I am wrong) that I should be concentrating on the FC levels. I though Higher PH levels made Chlorine less effective and the Higher the CYA, the more chlorine I would need. I figured once I got the pool unGreened, I would fix the other levels. Could this method be hurting my efforts?
    I think what you see in the pool is a little 20 buck PVC 'sprinkler' attached to one of the return jets. Very Soothing in these troubled times.
    Really - Thanks for all your help and advice. I just added 4 1/2 lbs of Mule Borax to the pool and will retest in about 2 hours when the sun starts to retreat. I figure I will also be adding more Bleach to the water as well after testing. I'll post the results that I get. - I'm off to one last Hardware store to AT LEAST get something to measure CC which may help fill in some holes in my pool picture.
    A very sincere thanks.
    CARLO.
  1. MY Intex pool is green and cloudy
    By reboot530 in forum Dealing with Algae & Slime
    Last Post: 08-24-2012, 01:30 PM
  2. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  3. Very Green Cloudy Pool
    By Robin N in forum Dealing with Algae & Slime
    Last Post: 06-30-2006, 12:43 AM
  4. Another green cloudy pool
    By hulla in forum Dealing with Algae & Slime
    Last Post: 06-27-2006, 09:25 AM
  5. Algae: brush or vacuum?
    By nectarologist in forum Dealing with Algae & Slime
    Last Post: 06-03-2006, 06:20 PM
