Thread: How am I doing so far w/out Bens kit?
    Kannapolis, North Carolina
    Default How am I doing so far w/out Bens kit?
    14 ppm fc
    1 ppm cc
    7.4 ph
    60 alk
    guessing the cya around a 30 done with a test strip
    27000 gallon IG pool
    sand filter
    Default Re: How am I doing so far w/out Bens kit?
    These readings are now a few days old. Can you update them? Hopefully with a FC of 14, that took care of your CC reading and it is now 0 which is where we want it to be. PH is fine. Alk is a little low. Add a little baking soda slowly to the skimmer to bump it up between 80-125. Also, get a test kit that uses drops rather than test strips. Hope this helps.
    Smile Re: How am I doing so far w/out Bens kit?
    I will update when I get home on everything but for the most part my pool is coming along nice, I can see the bottom of the pool and yes my cc has came down to 0, but I do have some debris on the bottom of pool that needs to come out and then its navigator city for me, these were my test results last night
    fc 6
    cc 0
    cya 30 I think using the Taylor kit, water about filled the tube before the dot went away
    ph 7.4
    alk 40
    I know that needs to go way up.
  1. Bens Bleach Calc???????????
    By traceyb in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-03-2006, 11:18 AM
  2. Bens Chart
    By Coolflee22 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-01-2006, 11:56 AM
  3. Bens kit
    By timmie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-28-2006, 11:41 PM
