Results 1 to 10 of 43
Thread: Brown stains spreading
    mbar's Avatar
    Ashland, PA
    Default Re: Brown stains spreading
    You can use muriatic acid, along with the stain treatment- which will be a much harder project. What is your ph now? How much sequestering agent did you put in? Before you start with the acid, I would let the water keep circulating. Make sure you have your ph down to 7 or 7.2 - you can lower it with muriatic acid, put enough sequestering agent in for a full dose according to the back of the bottle. I always add the whole quart for 10,000 gal. So you should have added the whole quart just to be safe. Let me know if this takes the stains off. If not, I will give you directions for the treatment with the muriatic acid, but you will need more ascorbic acid as well.
    Northeast PA
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    I am going out to test the Ph now. If it is higher than 7 I will bring it down.
    When I added water yesterday I added a quart of sequestering agent. Then today after the ascorbic I added another quart.
    I will post again tomorrow to let you and waterbear know what's happening and how the stains look. Since it's dark and the pool light doesn't work I can't really tell about the stain situation right now.
    I have the pump on recirculate. Should i leave it on all night?
    I'm going to order more AA in the morning. Whether I need it this time or not I'm sure I will need it at some point.
    Thanks for your help!
    Jul 2006
    Upstate, SC
    With my drops kit my Ph looks to be at 6.8 right now. What should I do? Can I add some borax tomorrow?
    mbar's Avatar
    Ashland, PA
    No, just leave it there, it won't hurt overnight, and it will help to get rid of the stains. You can take your ph up tomorrow using borax if the stains are gone. Let me know.
    Northeast PA
    Jul 2006
    Upstate, SC
    Thanks for all of yoru help. I will post tomorrow as to the condition of the stains and go from there. I placed an order from the chemistry store for 2# of ascorbic acid. They are a 2 hour drive from here and I would go pick it up if I had the time but it's just impossible since I am the single mom of an almost 2 year old. At any rate it shouldn't take long for it to get here since they are so close. If I still have stains we can try again. I'm determined to have a sparkling pool!!!!
    mbar's Avatar
    Ashland, PA
    You will, you may have a sparkling pool today - let me know - sometimes it takes the low ph to take off the remaining stain. Keep the filter running.
    Northeast PA
    Jul 2006
    Upstate, SC
    Today I have pretty clear water still but some staining remains. It is a whole lot lighter and almost something I could live with, but still a little bit stained and a little streaky. How should I proceed?
    Thanks,
    Gerri
  1. Pool stains brown after shocking.
    By Stroker in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-26-2013, 10:04 PM
  2. Brown stains
    By rick0312 in forum --cleanup--
    Last Post: 06-07-2013, 03:02 PM
  3. Brown stains on skimmer
    By bob66 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-22-2012, 07:21 PM
  4. Brown stains just about gone but a little cloudy....
    By babyj698 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-13-2012, 09:31 PM
  5. Brown stains on stairs??
    By MaryLee in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2006, 08:50 PM
