Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 43 of 43
Thread: Brown stains spreading
  1. #41
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    Default Re: Brown stains spreading
    Thank you so much for helping me. The pool guy is no help at all and if I had not found this forum I would have just been reduced to living with the stains, which really ruins it for me. It's terrible for everything to look dirty when the water is actually very very clean.
    Ok, hopefully tomorrow my AA will come IF the chemisty store are quick shippers. So it won't hurt keeping my Ph low for this long?
  2. #42
    mbar's Avatar
    Ashland, PA
    No, not if it is 6.8 - 7 is neutral - if it bothers you, then you can take it up to 7, by adding a little borax. You will get your pool nice and stain free - Just make sure you keep your ph on the low side when you start to balance the water after the stains are gone. High ph along with high chlorine is what makes the metals fall out of the water, so I always keep the ph low when raising the clorine, if I see some stain start to come back, then I add some more sequestering agent. Keep me informed on your progress.
    Northeast PA
  3. #43
    Jul 2006
    Upstate, SC
    I will definitely let you know how it all goes. And again, thank you VERY much. I hope my AA comes tomorrow.
  1. Pool stains brown after shocking.
    By Stroker in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-26-2013, 11:04 PM
  2. Brown stains
    By rick0312 in forum --cleanup--
    Last Post: 06-07-2013, 04:02 PM
  3. Brown stains on skimmer
    By bob66 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-22-2012, 08:21 PM
  4. Brown stains just about gone but a little cloudy....
    By babyj698 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-13-2012, 10:31 PM
  5. Brown stains on stairs??
    By MaryLee in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2006, 09:50 PM
