Thread: Which type winter cover?
    Sep 2011
    Massachusetts
    Lightbulb Which type winter cover?
    I have a 21' above ground round pool. I'm looking at buying a winter cover this year but I'm unsure which kind or brand to buy. I'm a fairly new pool owner (bought last yr). I didn't cover the pool last year going into winter as I felt at the time it would be easier not to. I'm looking to change that this year due to the constant leaf cleanup throughout most of the fall.
    What's the opinion here? I do have 2 large trees behind the pool in the neighbor's yard that release their leaves in the pool. Is it easier with a mesh style or solid? Also what is a good brand to buy?
    thanks.
    Sep 2011
    Massachusetts
    Default Re: Which type winter cover?
    Anybody willing to give any recommendations?
    They both have their advantages and disadvantages.
    With mesh, the water flows right through but with it, so does some dirt. But, you do avoid having to pump off the top of the cover if you get a lot of rain or snow in the winter. On the other hand, since it isn't solid and you do get sunlight into the water, you sometimes have to deal with algae moreso that with a solid cover which blocks the sunlight.
    Solid covers do keep the water cleaner but you occasionally may have to use a submersible pump to pump off the cover. Plus, decaying leaves on top seem to most always end up in the clean pool when you remove the cover in the spring. You also will probably want to use some type of air pillows or large inner tubes to keep water from puddling in the middle of the cover putting stress on the pool walls.
    For the past several years, I have not used a cover. I keep after the leaves in the fall as I also have trees around my pool. (My Polaris 65 is good for getting leaves out of the pool.) But, then, once the leaves have all fallen from the trees, that's it. The water stays clear all winter. I do have a little dirt on the bottom in the spring but that is easily vacuumed up. (My Wanda the Whale vac is better for dirt.) I got tired of fooling with that huge cover and cleaning it upon opening was also a pain.
    Sep 2011
    Massachusetts
    Thanks, maybe I will continue to keep it uncovered. It is initially more work cleaning out the leaves but once they're all down, maintenance is kept to a minimum.
    Thumbs up Re: Which type winter cover?
    Lisa, that is a GREAT synopsis of mesh v.s. solid covers -it should be stickied!
    The only other thing I'd mention is that, if a mesh cover has leaves on it and the water level is high enough that the cover is sitting in the water, you'll be 'making tea' and the water will turn brown or green - so you either need to keep the leaves off the cover or keep the water low enough to prevent the mesh cover from sitting in the water.
  1. What type of winter cover should i buy?
    By Jimcarter46 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-20-2011, 10:08 PM
  2. Has anyone used ANY type of pool cleaner with an automatic cover in place?
    By cscannon in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-21-2010, 04:10 PM
  3. Solar cover under winter cover?
    By margekendall in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-18-2006, 10:49 AM
  4. Tips, suggestions on what type of solar cover to buy & where?
    By MTU 5.0 in forum Pool Equipment & Operations
    Last Post: 07-14-2006, 10:53 PM
