Thread: Floater Tabs
    May 2012
    North Carolina
    Default Floater Tabs
    Are there floater tabs that do NOT raise CYA? I really don't want my CYA much higher than 60 ppm and it keeps creeping up higher than that.
    And does it take a long time for CYA levels to decrease?
    Peggy (TheKs)
    14 ft. x 4' round AG vinyl pool; 6% bleach; some dichlor shock, some trichlor tabs; Dry acid; Muriatic acid; 1 speed Intex SF15110 SAND filter/pump; 6-8 hrs; Taylor K2006; utility water; no covers yet
    Lehigh Valley, PA
    Default Re: Floater Tabs
    No, there aren't. Chlorine products in solid form either contain CYA (trichlor tabs, dichlor granules) or calcium (cal-hypo granules). The only chlorine product that doesn't contain CYA is bleach.
    CYA levels decrease as a result of dilution. When you have a lot of splashout and refill frequently you're diluting the CYA a little. When you backwash and rinse your sand filter and then top off the water level you also dilute the CYA some.
    At a CYA of 60 I would go with bleach and not use the floater tabs or the dichlor shock and go with regular household bleach.
    Oval 12.5K gal AGP; Hayward 19" sand filter; Pentair Dyn 1 HP 2sp pump on timer
    [URL="http://www.ellerbach.com/Pool/"]My Pool Pages[/URL]
  1. Automatic chlorinator or floater?
    By Rickb in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-14-2012, 07:15 PM
  2. Bleach and Floater Use
    By NiteSwimmer in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-05-2011, 10:58 AM
  3. 3" tabs in floater or skimmer?????
    By traceyb in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-25-2007, 10:01 AM
  4. Borax Floater in Closing Kit
    By Jakebear in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-30-2006, 09:52 PM
  5. Can I use bleach if there are still pucks in the floater
    By Krissti5 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-15-2006, 09:48 AM
