Thread: adding baking soda
    Default adding baking soda
    When adding baking soda to rise Alkalinity do I just dump it in the deep end and spread around like acid or in the skimmer?
    Mike
    duraleigh Guest
    Default Re: adding baking soda
    I've only done it in the skimmer. Dissolves quite rapidly.
    I just add it to the skimmer. I add 1 lb, wait a while (like a day), test, and add another lb if it needs it. I'd rather get to my target slowly than over shoot it. Once T/A passes 100ppm, I stop.
    gregugadawg Guest
    baking soda should just be added directly to the pool water
    Quote Originally Posted by mikewaterskis
    Mike
    if you dump it in the pool brush throroughly afterward to help dissolve it. You can pour it into the skimmer if you like or you can dissolve it in a bucket of pool water and broadcast it over the surface of the water. wait about 24 to 48 hours before testing the ALK level since you need to give it time to dissolve completely and incorperate into the buffer system in the water.
    MOst of us add it to the skimmer
  1. pH to high after adding baking soda to raise TA - Help Please
    By myLABSpool in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2010, 01:30 PM
  2. Adding baking soda when pH is high??
    By Henrys514 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-17-2007, 03:33 AM
  3. How much baking soda can I add in a day?
    By mwsigler in forum Dealing with Alkalinity and Calcium
    Last Post: 06-16-2007, 07:45 AM
  4. is adding baking soda ok if chlorine is high
    By traceyb in forum Above-Ground Pool Construction & Repair
    Last Post: 06-06-2007, 07:16 AM
  5. Baking Soda How To Add
    By msb1766 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2006, 08:39 AM
