Results 1 to 10 of 14
Thread: Removing Dead Algae from the pool-SOS
    Sanford, FL
    Default Re: Removing Dead Algae from the pool-SOS
    Flocculant is supposed to make everything fall to the bottom of the pool so you can vacuum to waste.
    Clarifier makes small particles larger so your filter can catch them better.
    Most people on the forum do not recommend regular use of either of them. If you want more info, you can use the search feature to find threads that specifically address both products.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    pratzert is offline Lifetime Member Thread Analyst pratzert 0
    Thanks for the info.....
    Tim
  1. Can't get rid of tons of dead algae on the bottom of my pool
    By amillionpets in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-20-2013, 11:23 PM
  2. Removing Dead Algae
    By steews4 in forum Dealing with Algae & Slime
    Last Post: 07-07-2012, 06:39 PM
  3. Dead Algae. Pool blue but cloudy won't filter
    By Patty16 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-25-2012, 10:28 AM
  4. help me -- the algae is dead, but my AG pool is cloudy
    By jonboy1 in forum Dealing with Algae & Slime
    Last Post: 04-17-2012, 02:37 PM
