Thread: Upgrading to Intex sand filter
    Aug 2012
    Louisiana
    Question Upgrading to Intex sand filter
    I recently purchased an Intex sand filter/pump for my Easy Set 18' x 48" pool. The pump included new intake and output fittings (the intake seemingly more substantial than original), yet the new intake has no attachment for the vacuum hose. I was wondering if it was ok to leave original in/out fittings to use vacuum hose or would I need to switch them (for the stronger bigger pump) or if there was another solution?
    PS the fittings in question are the ones inside the pool (wall parts).
    Any help would be appreciated, thanks!
    Default Re: Upgrading to Intex sand filter
    I'm not sure -- some others here may be. BUT, I am sure you'll get much better answers if you post pictures. (Picasa, Photobucket, Webshots, Flickr are all OK)
    membership updated. -ben
  1. Debating upgrading Intex cartridge to sand filter...
    By 7sanders in forum Intex-type Pool Setup & Operations
    Last Post: 06-17-2013, 05:55 PM
  2. Upgrading 18 x 52 Ultra Intex AGP with Built in Skimmer & PVC
    By wpmachine in forum Above-Ground Pool Construction & Repair
    Last Post: 05-29-2013, 11:03 AM
  3. Intex Sand Filter - Just pooped in my pool!
    By KeggerTx in forum Pool Equipment & Operations
    Last Post: 09-13-2011, 12:58 PM
  4. best intex sand filter for 16x48 pool?
    By anikahmae in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2011, 08:13 AM
  5. Upgrading an Intex pool to sand filter....
    By aylad in forum Above-Ground Pool Construction & Repair
    Last Post: 08-12-2010, 12:59 PM
