Results 11 to 13 of 13
Thread: New pool owner
    Default Re: New pool owner
    Since 5ppm is the limitation of the chlorine tester in your kit, your chlorine could be 5 or higher. Use a dilution method to get a better reading. Testing Without a Good Kit
    Repost after you do this.
    Aug 2012
    KS
    The last paragraph of the link talks about Phenol Red, which in my test kit is for pH?
    Anyway, with the OTO yellow I ended up getting a reading of 3 at a 3:1 dilution; or 12ppm if I'm doing this right.
    Note that the pool water just barely has a chlorine smell, if that is any indication at all.
    15 round 2.8K gal Intex AG vinyl pool; hand fed granual; intex type A cartridger; Krystal Clear model 637R, 1,000 gph pump; 4hrs; HTH 6 way test strips; well; summer: Intex cover; winter: pool down and stored; android phone; PF:43
    May not need muriatic.
    Continued use of dichlor should drop the pH. Also, if you have algae, use double doses of dichlor till you do NOT have algae.
    Ben
  1. New Pool Owner
    By HMSpool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-20-2012, 10:32 PM
  2. New pool owner
    By Ameztoy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-27-2012, 09:06 PM
  3. New Pool Owner!
    By Kainoa in forum Pool Equipment & Operations
    Last Post: 11-13-2011, 09:35 PM
  4. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
  5. New Pool Owner
    By bobcat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-25-2010, 03:03 PM
