Results 1 to 10 of 13
Thread: New pool owner
    Aug 2012
    KS
    Default New pool owner
    Greetings all! Proud new owners of an Intex 15" AG pool currently set up in a temporary location in the back yard. It was filled with well water but I have it pretty well balanced, if only the water will warm up a little more.
    We're planning to take it down and store it for the winter in about a month, next spring we'll level a spot closer to the deck that will become it's permanent home.
    As a first time pooler, I look forward to learning a lot from this forum.
    Greg
    15 round 2.8K gal Intex AG vinyl pool; hand fed granual; intex type A cartridger; Krystal Clear model 637R, 1,000 gph pump; 4hrs; HTH 6 way test strips; well; summer: Intex cover; winter: pool down and stored; android phone; PF:43
    Default Re: New pool owner
    Welcome to the Pool Forum!
    Aug 2012
    KS
    Quote Originally Posted by PoolDoc View Post
    You might want to read this: http://www.poolforum.com/pf2/showthread.php?9755
    Your privilege status when I update your membership is dependent on that info.
    I did the pool chart and facebook before I posted here, I don't twitter so couldn't do that one.
    I'm still working on the auto-upgrades. You should got to "Registered+" in a day or so.
    Looking at your pool chart info, I see that you have well water and are using 'guess-strips'. That tends to be a toxic combo -- well water is often problematic, and with guess strips you really don't know what you're dealing with.
    I'm posting some relevant info for you below; hope it helps.
    Ben
    + Get a cheap OTO (yellow drops) / phenol test kit, or if available at YOUR Walmart (check availability), get the HTH 6-way DROPS test kit, which is compatible with the Taylor K2006. Test the pool as soon and you can, and post the results. If you get the 6-way kit, ALSO test the water you FILL the pool with, especially if it's a well, and post THOSE results as well. (The HTH is the best available kit you're likely to find locally, but it's not the K-2006. It can only provide rough measurements chlorine levels above 5 ppm, and it measures "TOTAL" hardness, rather than "CALCIUM" hardness, which is not ideal.)
    + Having a good test kit makes pool care easier for EVERYONE, but is an ESSENTIAL tool for pools with problems. A good test kit means a kit that can test chlorine from 0 - 25 ppm, pH, alkalinity, calcium hardness, and stabilizer with reasonable accuracy. Test strips (AKA 'guess-strips' ) do NOT meet this standard. Some pool store testing is accurate; most is not. The ONLY way you'll know whether your pool store is accurate or bogus, is by testing accurately your own self. On the other hand, pool store 'computer' dosing recommendations are NEVER trustworthy -- ignore them. They are designed to sell more chemicals than you need, and WILL cause many pool problems.
    + We recommend the Taylor K-2006 test kit, which meets the requirements above, for many reasons. The HTH 6-way drops kit is a great starter kit, and is compatible with the K2006 (it's made by Taylor). There are a few alternatives; for example Lamotte makes an FAS-DPD kit that's OK -- but it costs 3x as much. But, we're not aware of any test that is better, and since we are all familiar with the K-2006 (and can help you with it) we recommend it exclusively ( Test kit info page )
    One caution for the 2012 season: Amazon does not stock the kits directly. So when buying at Amazon, Amato is our current preferred seller. However, they often don't list enough stock to last the whole day, so try order mid-morning. You should expect a delivered cost under $60 for the K2006A and under $95 for the K2006C. If you can't find that, wait a day.
    + Here are links to the kits we recommend (you can check local availability on the HTH kit, using the Walmart link):
    HTH 6-Way Test Kit @ Walmart
    + Pool tests for metals aren't always reliable, for a variety of reasons. If there's a chance you may hve iron or other metals in the water you fill your pool with, using a bucket test can verify the problem: http://www.poolforum.com/pf2/showthread.php?16946
    + Filling with metal contaminated water is tricky. Often, by the time your pool is full, it's already stained. If you think (or know) you have metals in your fill water, it is best to wait till you have a complete treatment plan -- and all testkits and chemicals ready and waiting -- BEFORE you fill. If it's too late for that, but your pool has not yet turned brown, or started staining your pool, then do this:
    • Lower your pH to 7.0 - 7.2)
    • Add a dose of pool store LIQUID metal control agent. Do NOT over dose. Do record EXACTLY what you use, because we'll need to know.
    • Buy and use some polyquat but do NOT use chlorine.
    If everything is already all brown, do the same as above, BUT maintain low (1 - 3 ppm) levels of chlorine.
    + The OEM cartridges in Intex / Summer Escapes / etc. filters are not high quality. The Intex manuals recommend replacing them completely every 2 weeks. A BETTER option is to replace them permanently with 2 - 3 Unicel cartridges, and rotating them through a cleaning solution. Properly maintained, the Unicel cartridges will last all season AND will filter better. So even though they cost more per cartridge, they cost less per season! Learn to maintain them, by reading this post, Cleaning-your-Cartridge-Filter-wiithout-Damaging-It!
    But, purchasing them is tricky. Amazon does not consistently stock them, and some of the 3rd party sellers are charging high prices and/or high shipping. So, check the Amazon link, but watch out for the prices and shipping costs.
    It would be nice if you could just buy them elsewhere, but many of the online pool stores are listing Pleatco or other Asian made low quality filters, as "Unicel C-4607 type" or "fits Unicel C-4607". So shop carefully!
    Here are the Amazon links:
    Unicel C-4607 Replacement Filter Cartridge (Easy Set Size A or C) @ Amazon
    Unicel C-5315 Replacement Filter Cartridge for 15 Square Foot Intex B Filter @ Amazon
    Aug 2012
    KS
    OK, we got the HTH 6 way drop test kit and pool is;
    Cl 1
    pH 7.2
    Alk 400
    CYA less than 30, the dot never disappeared
    Hardness 370
    Quote Originally Posted by Gomez5693 View Post
    Alk 400
    Hardness 370
    Ouch! Keep your pH low!, as in 7.2 or lower. You'll need to read the muriatic acid page linked in my signature, and then get some. Your pH is going to constantly tend to drift up.
    You also may want to do a metals bucket test
    to see if you hit a home-run (high TA, high TH, AND metals).
    + Do NOT use any calcium hypochlorite based chlorine.
    + Do NOT add pH Up (soda ash, washing soda), or Alkalinity Up (baking soda)
    + Do NOT let your pH get above 7.4
    + Do use dichlor, to chlorinate (info below)
    + Do NOT add large dose of chlorine all at once.
    + If you are not on a tight budget, do get some polyquat (info below) and use it to allow you to run lower chlorine, till we work out a plan.
    Your pool water is very 'twitchy', and will turn to 'milk' if you don't follow the guidelines above. If you don't also have metals, we can just lower your TA, and then you can go about things pretty much as usual. If you DO have metals (iron!) in the water, then you've got some work to do.
    Ben
    + If you need stabilizer, and have access to a Sams Club, buy their 24 pack of 1# bags of dichlor shock. Each bag will add about 7 ppm of chlorine, and about 6 ppm of stabilizer, per 10K gallons of water. Otherwise, order dichlor from Amazon:
    Kem-Tek Dichlor 22 lbs
    We do NOT recommend buying dichlor locally, otherwise, at least until you are an EXPERT reader of chemical labels. The chlorinating pool chemicals sold at Walmart, Kmart, Costco, and most other local stores are diluted blends, sometimes with copper and other products with bad side-effects
    + Chlorine is the strongest algaecide you can buy . . . but occasionally, you may need a different one. Almost the only alternative algaecide we recommend is polyquat -- poly [oxyethylene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride] . This product is a GOOD clarifier and a moderately good algaecide, with almost no bad side effects. We often recommend it for use when you are going on vacation, or when you need to lower your chlorine, to prevent remove stains. It has become quite difficult to purchase locally at the normal full strength 60% concentration. If you find it locally, at a 60% concentration, that's fine. But be SURE to check the chemical name. If you need to buy it online, here's an Amazon link:
    Kem-Tek 311-6 Pool and Spa 60-Percent Concentrated Algaecide, 1 Quart
    Last edited by PoolDoc; 08-08-2012 at 09:23 PM. Reason: corrected paste-in content
    note correction to polyquat paste-in . . . NOT the same as in the emailed version of the post.
  1. New Pool Owner
    By HMSpool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-20-2012, 10:32 PM
  2. New pool owner
    By Ameztoy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-27-2012, 09:06 PM
  3. New Pool Owner!
    By Kainoa in forum Pool Equipment & Operations
    Last Post: 11-13-2011, 09:35 PM
  4. new home owner -- new pool owner -- clear as MUD
    By Andyman33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-06-2011, 07:51 PM
  5. New Pool Owner
    By bobcat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-25-2010, 03:03 PM
