Anything that causes splashing will aerate the water. You can also turn your return jet upward so that it causes splashing at the surface of the water. That will also help.
Thanks to all! And good to know about the waterfall! My spa spills over into the pool, also so that is something to take into consideration as well. Love this forum!
oops-one more question- using my taylor test kit and testing TA, when color is supposed to change from green to red, is it true red? Or should I stop when it changes at all (pink)?
It is not true red. A definite change from green to pink is what you are after.
Taylor videos here: http://www.poolforum.com/pf2/showthread.php?17157
basically just keep adding drops until a drop produces no more color change and then don't count that last drop. Same with the calcium hardness test.
