Results 1 to 10 of 40
Thread: Pool Survived Vacation! ?? Chlorine levels
    mroll is offline Subscriber Thread Analyst mroll 0
    Jun 2012
    Long Island, NY
    Default Re: Pool Survived Vacation! ?? Chlorine levels
    Sorry, I didn't mean to scare you, you've been asking what's going on - so - I gave you my thought about your chlorine demand.
    I think that 4ppm FC is too low and you need to add some more bleach or Liquid Chlorine (LC) sooner than later.
    If you don't see or feel any algae then let's stay with regular FC (5ppm - 10ppm) levels for a while.
    Well walls DID feel little slimy but water still clear..Test FC was back down to 2 PH down to 7.4 SO I put in 4 cups of the liquid shock. Is that enough? Chlorine was so stable for so long.. Do you think this is cause of heavy rains?? Was no heavy use age..
    thanks again...
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar; winter: Not bought yet; ; PF:21??
    Jun 2012
    Long Island, NY
    Quote Originally Posted by mroll View Post
    thanks again...
    Just added 6 more cups of shock after reading further on this forum..Hopefully that should do it....
    BigDave's Avatar
    Rain doesn't cause high chlorine demand, the beginnings of an algae bloom do. I think it's pretty clear that algae's got it's foot in the door and it's time to shock.
    As I recall your last reported CYA was 55 - how did you come by that? Half way between 50 and 60? Let's use 60 to be safe.
    According to Ben's Best Guess Chart the shock level for your pool's CYA is 20ppm. One large jug (182oz) of plain household beach should get you there to start. Put it in, brush the pool, and test FC and CC half an hour later. Add bleach as needed to get the FC above 20ppm.
    As often as possible (at least twice a day): Test FC and CC. Add bleach as needed to get the FC above 20ppm. ( In your pool each Cup of 6% bleach adds 0.7ppm of FC )
    Brush the pool daily.
    Run pump / filter 24/7; clean as needed.
    Continue until one day after you you have 1ppm or less FC loss overnight ( test FC near sundown and again near sunrise ) and there is 0.5ppm or less CC and the water is clear. The one day after is to be sure we've got it all.
    You can swim but wear an old suit as swimwear might be damaged by the shock level FC.
    Jun 2012
    Long Island, NY
    HELP!!!Before you posted I ran out and tested .FC was 7.5. I'm leaving in a bit I can throw in 1 gallon more of bleach and run filter before I go (Canot brush) OR I can test again around 3:30 when I'm back and see if I'm still loosing chlorine. Then either leave it or proceed with your instructions of throwing more in. Which should I do???
    BigDave's Avatar
    Put the gallon of bleach in and brush when you get home. Buy some bleach while you're out. Run the filter.
    Jun 2012
    Long Island, NY
    Sorry.. Confused..Bleach in NOW ...Brush Later...Filter Now??? or everything later?
    BigDave's Avatar
    Yes, put bleach in now.
    Brush when you can.
    Filter all the time.
    Start the shock process as soon as you can.
    Sorry for being unclear.
  1. First "Pool-tastrophe" survived...mostly
    By RxDoc in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-16-2014, 10:37 PM
  2. Going on vacation, what chlorine level to leave pool at?
    By sunlove in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2012, 02:33 AM
  3. How often to test & how much chlorine to add daily? Also, vacation upcoming...
    By blessedbeingmom in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-16-2010, 10:36 AM
