Results 1 to 10 of 40
Thread: Pool Survived Vacation! ?? Chlorine levels
    mroll is offline Subscriber Thread Analyst mroll 0
    Jun 2012
    Long Island, NY
    Default Re: Pool Survived Vacation! ?? Chlorine levels
    Yesterday FC said 2 and CC 8 which did NOT make sense. Put in 3 ounces of dichlor to raise CYA as suggested.
    This morning with basic test clorine was way over 3 and then this evening FC 4 CC.5 and did CYA test which read about 55. So I put in 3 cups bleach. So now I'll stay with bleach right??
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar; winter: Not bought yet; ; PF:21??
    BigDave's Avatar
    Sorry for not checking in - I was completely (almost) offline - camping with WEBELOS.
    Yep, with a CYA of 50ppm to 60ppm you are good. I think you should be adjusting bleach dose to maintain an evening FC of at least 5ppm (test before adding bleach). Let's call the FC 2 / CC 8 test anomalous, but do keep an eye on CC.
    Jun 2012
    Long Island, NY
    [B]OMG..Cannot keep chlorine level up!!!Yesterday in evening FC was 2 so put in 4 cups of bleach..[/B]This morning (after tremendous rains last night)FC was .5!!!! I have gallon of shock from Leslies. I want to put in half of it. WHAT do you think??? Where is my chlorine going???
    BigDave's Avatar
    That's probably too much. Try 4Cups (1qt). and lets see where that moves your FC, CC and pH. What is your pH now, after the rain?
    Jun 2012
    Long Island, NY
    PH 7.3..Just added 4 cups shock..When should I test again? tonight right?
    BigDave's Avatar
    Can you test about an hour after adding the liquid chlorine? Let's see where that moves the FC, CC and pH.
    Jun 2012
    Long Island, NY
    OK did FC was 3 and CC .5 Forgot to do PH... Will...
  1. First "Pool-tastrophe" survived...mostly
    By RxDoc in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-16-2014, 10:37 PM
  2. Going on vacation, what chlorine level to leave pool at?
    By sunlove in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2012, 02:33 AM
  3. How often to test & how much chlorine to add daily? Also, vacation upcoming...
    By blessedbeingmom in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-16-2010, 10:36 AM
